Bars to be narrowed
Old 03-19-2014 | 10:20 PM
Tacoma660's Avatar
Default Bars to be narrowed
Just got my pro taper bars in cr high and looking to narrow them up. What is the best way to cut the bar?
Old 03-19-2014 | 11:33 PM
pghxd9's Avatar
Measure, tape, hacksaw! My recommendation is to be conservative when cutting. A little goes a long way, so to speak. I've seen friends cut up to 2 inches off each side and then they never could get comfortable on longer rides and had to scrap the bars.
Old 03-19-2014 | 11:49 PM
I have used a small plumber's pipe cutter they'd use on copper and small steel pipe. I'll be using them again when I cut down the Renthals on the 250 shortly.
$4.99 at Harbor Freight.
Old 03-20-2014 | 12:15 AM
+1 on going conservative. I cut some short, back in the day, and afterward there wasn't room for the grips , perches, and switches. I had to go buy a second set of bars. Wow did that suck! In any case, measure how much real estate your grips etc take up, then cut.
Dan
Old 03-20-2014 | 12:39 AM
Dan
D
Dan, hard to believe you did that. I know you had to find a decent use for that short bar later.
Old 03-20-2014 | 01:18 AM
Originally Posted by TNC
D
TNC , I know you are just laughing AT me, but I'll humor you with a response.
Honestly , I don't remember what i did with the short bars. I think I gave them to a buddy that put them on a hill-climb bike he was building.
The bars I replaced the "too short" bars with were on my old "85" KLR, and when i got the KLX in 2008 I put them on it. They are Renthals, but I don't know what bend. I think I ended up taking an inch off each end way back when. When I started riding my Husqvarna I got last year, the bars felt really wide, and I had a harder time squeezing between some of the trees. I plan on cutting the huskies bars down.
Old 03-20-2014 | 04:16 AM
ol'klx-er's Avatar
Don't cut the bar just yet, ride the bike some with the bar full width for a while.
Old 03-20-2014 | 04:32 AM
PalmStateCrawler's Avatar
That little pipe cutter from harbor freight works great. I bought some protaper klx110 bars for my bw80 and they were too wide. The bar cutter is easy to use and makes perfect cuts.
Old 03-20-2014 | 11:38 AM
doum's Avatar
I have the protaper wood low and I love them in tight woods! Those bars are 1" shorter, so only 1/2" less on each side, and I don't think I would go any shorter than that.
Old 03-20-2014 | 05:12 PM
RaceGass's Avatar
Atv bars usually have the rise more abrupt so the area for grips perches signal switches is greater.
Quick Reply: Bars to be narrowed
