Baker 1.1 gallon Auxillary tank, 09KLX250S
This tank basically completes the build on this bike. It's just what it needed to get the range up to 150 miles, even when riding fairly hard.
Assembly is straightforward, if you've two synapses that communicate. The one-way check-valve (optional, but, a good thing to have inline in case one of your two synapses short-circuits) requires a zip-tie on each end to snug it down in the fuel line, but, what's a Dual-sport without a few zip ties? A Garage Queen...that's what!
The tank hung tight with no discernable wiggling through miles of whoops, sand, rocks, and multiple hillclimbs (did I mention how much I love the Bill Blue 331 kit on hillclimbs?). It even withstood a downhill sand nap on the aux tank side following an unexpectedly high drop-off down a mountianside (hey, it was sand, steep, and I couldn't stop...so I had no choice at that point!). Due to the bike being upside down for a bit, I got a pretty big airlock in the line from the tank to the carb.
The "cure" for that much deadspace, which coincided with the tank being almost empty (therefore minimal hydrostatic pressure head provided by the fuel) is to turn ON the main petcock, which chopped the air lock in half, and run it for a couple of miles that way, then turn off the main petcock. Again, the one-way valve can complicate that series of steps, but, it prevents draining the main tank into the aux tank if you forget to cut off one of the petcocks. You know...in case the synapses mis-fire.
I got out on the highway and ran the tank until the bike sputtered. I'll have to fill it up now to see how much of the 1.1 gallons was used. There is still a little fuel left in the line...so, I shortened it when I got home. I may also shorten the line from the T below the main petcock to the carb, as there is now a little bit of a loop. Any extra line, or loops like this one, can exacerbate the effects of airlocks that will inevitably be found in the line.
Now, I know I can go at least 150 miles with the fuel in those two tanks, even when riding my 331 pretty hard.
I'm thrilled with this tank. I think it might be even better than putting an extra gallon up high on the bike. Besides, I need the extra range now, not "tomorrow"...especially when the definition of "tomorrow" is unknown for the 09's and 10's.
Thanks to BandBMoto, and my local suspension expert, I have a really great little dual-sport!
As a semi-luddite, that just hasn't been on the front burner. I'm out of town the next couple of days...maybe by Wednesday I'll have some pictures.
I know, I know...PICTURES! Maybe Wednesday!
Thanks for the kind remarks!
Bill and I always knew the KLX250 had the makings of a great dual-sport and trailbike but, in our opinion, it had two shortcomings. It needed more power and especially low end torque, and it needs a better fuel range. We think our inventions addresses these issues and the result is a bike that can reach much of it's potential.
However, if the bike did begin to sputter from fuel starvation, the fix is to simply reach down and turn the main petcock to "on" or "reserve" until you reach the top of the hill, then, turn it back to "off". The inline one-way valve will prevent fuel from the main tank from backfilling the aux tank.
