Bad news on KK330
#41
if you are going to use the same piston, send it to BB so he can at the very least match the bore to the WORN piston. I can guarantee the piston is no longer round and the side skirts are worn... not a good idea in any rebuild.
Sometimes we think about going cheap and end up spending double.
This makes no sense at all. Go for the NEW MATCHED piston, will have regrets if you don't.
#43
thats right, they are cam ground, they should be round at working temp
#44
you guys are spoiling the bet..
it was a WIN WIN.
The point is:
the skirts are most likely worn,,,if the bore in not matched to the piston it will slap causing premature failure because someone wanted to save money.
We can discuss all day how much wear is acceptable to re use a piston in a NEW bore.
Personally, i never would do it.
Just my $.02
it was a WIN WIN.
The point is:
Just my $.02
#45
RTFM
Page 167 from the manual posted here.
Piston/Cylinder Clearance
• Subtract the piston diameter from the cylinder inside diameter to get the piston/cylinder clearance.
Piston/Cylinder Clearance Standard: 0.035 -0.062 mm (0.0014 -0.0024 in.)
*If the piston/cylinder clearance is less than the specified range, use a smaller piston made within the standard diameter or increase the cylinder inside diameter within the standard diameter by honing.
*If the piston/cylinder clearance is greater than the specified range, use a larger piston made within the standard diameter.
*If only a piston is replaced, the clearance may exceed the standard slightly. But it must not be less than the minimum, in order to avoid piston seizure.
You can also use a long feeler gauge in the cylinder with the piston you want to use.
Don't take a simple job and turn it into a blow job.
Measure the piston and bore.....
David
David
#46
I will send the piston to Bill just to be safe but I dont see how its worn much as the machineing groves are all still there from top to bottom, any apreciable wear would surely be noticeable as rounding off or the groves gon completly. But flame away I dont mind.
