Anyone who has taken apart the KLX motor - help please!
Old 01-12-2015, 03:00 AM
MaximusPrime's Avatar
So you're running?
Did you swap stators?
  #42
Old 01-12-2015, 01:18 PM
smithjNW's Avatar
So you're running?
Up and running! I did swap the stator. I've been posting about it over on ADV: KLX250 Engine Replacement - ADVrider
  #43
Old 01-14-2015, 10:34 PM
rgmr250's Avatar
...I got stopped at needing a beefier philip's head screwdriver (impact driver??) to pull the oil pump. I can't believe they use philips screws there. ...
Just a note on this - note the difference between a Phillips head screw and a JIS head screw. A Phillips screwdriver has a very good chance of stripping a JIS head screw (which I believe, pretty much all Japanese bikes use, rather than Phillips), but a JIS screwdriver will work for JIS and Phillips screws. Google it if you need more info. I've heard of lots of 'phillips' screw heads (which were actually JIS) getting stripped out, where a JIS screwdriver likely wouldn't have caused the damage.
  #44
Old 01-15-2015, 01:26 AM
+1 on that
firstninjabike
03-10-2008 01:44 PM
aszrael1266
08-29-2007 07:46 AM
jds636
09-09-2006 05:30 AM
Quick Reply: Anyone who has taken apart the KLX motor - help please!
