Anyone using this new Ignitor box?
Wondering if any of these are in use by list members.
KLX CDI module
In particular wondering if the additional advance can really be felt at higher RPMS.
If you are running one what else has been done to your engine?
L D
KLX CDI module
L D
I'd be interested in trying out the Aussie setting.
I think I'd carry my stock CDI for awhile, $189 CDN seems too inexpensive, but what do I know.
I'd be curious about how it works on the big bore when switching between US and Australian timings. Big bore is my next step...finally. Then pumper...then maybe try the CDI. Hopefully someone else will have been the guinea pig by then.
If I recall correctly, someone on this forum was developing a adjustable cdi and during the development process he found that there wasn't any change in power with the increased timing. The only advantage I can see using this box is a huge discount($180) versus the oe unit($350).
You are right GBAUTO, the dyno test of the CDI and it's various ignition advance options proved that it added no hp. The test was quite an upset to the member that developed it.
All this can be found by searching the forum.
