Any differences between 2006 and 2007?
I've been interested in changing out my 2012 KLX250 for a 2006 due to the extra suspension travel on the 2006. I've found a 2007 KLX250 that's for sale. Almost everything I've read is that the 2006 and 2007 are identical but I also remember reading something about Kawasaki starting to reduce the suspension in 2007? Anyone know if that's true?
Thanks!
Thanks!
Same I thinks
I hunted specifically for an '07, simply because they were better suited for off-road from the factory, than the later models. IMHO
I found an '07 in July with just under 600 miles on it, never been in the dirt, so I snatched it up. It's my belief the 2006 and 2007 have identical specs. If your over 200#, plan on getting heavier springs though. The fork springs feel like they are out of a KX60! But all the KLX's are like that from what I hear/read.
Dez
Dez
Cosmetics
The 06 has a green and white headlight shroud. The 07's shroud is all white.
I think the seat might have a slight cosmetic difference too.
I'm sure you already knew this, but just for the record.....
Ditto on the springs. Heavier springs transformed my 06 into a much better handling bike. I'm almost 220 and the springs that worked for me were 0.44kg/mm in front and 6.0kg/mm on the rear shock.
WVHunter129
08-03-2022 05:33 PM
strommer
07-16-2010 08:24 AM
