Air Fuel screw?
Old 04-14-2009 | 03:19 AM
Savage's Avatar
Default Air Fuel screw?
Advice ASAP - Getting ready to order the DJ kit for my 300. Do I have to buy and install and fuel screw too? I don't want to if you don't think it's necessary.
Thanks!
Old 04-14-2009 | 03:33 AM
WestOzKLX's Avatar
No. Just get a cheap screwdriver the right size and put a 90o bend in it near the end. You can then adjust the fuel screw without removing the carb. The DJ kit for the 300 is the go.
FIGHT MY BRUTE
Old 04-14-2009 | 03:37 AM
Savage's Avatar
OK, great. So I should remove the air fuel cover while I have the carb out?
Where can I find info on how adjust/jet the new kit for my altitude? Thanks!
Old 04-14-2009 | 03:54 AM
WestOzKLX's Avatar
Mate you don't have any altitude. Try the #132 main jet (largest) first and then work your way back. Needle in the middle position. A little rich is better than a little lean. And yes, pop the cover off the fule screw before you re fit the carb. It's a good time to size up that cheap screw driver mod I mentioned so when the carb' is fitted back up you can adjust the screw easily.
Old 04-14-2009 | 04:23 AM
Savage's Avatar
Thank you!
Old 04-14-2009 | 04:48 AM
Fourty2ri's Avatar
I would buy the t-handle screw from Kouba. You can play with a bent screwdriver, but it a PITA. There aint much room in there, with the t-handle you can get your hand in there and adjust it.
Just my $0.02
Old 04-14-2009 | 07:13 AM
RaceGass's Avatar
On the 300 theres no electric starter so there is abit more room, but for the ease of adjustment the kouba is sooo much better. No messing w/ a tiny screwdriver
markturbo
02-25-2008 01:18 PM
LordVngr
09-16-2006 04:49 AM
krntl13
07-23-2006 03:58 AM
mario66
07-12-2006 07:44 PM
ZX_9r
05-13-2006 07:46 PM
