air filter cleaning
Old 11-18-2007, 08:10 PM
The frog's Avatar
Default air filter cleaning
What are you guys using to wash your air filter. I need to clean mine (I still have the original one)?
Old 11-18-2007, 08:22 PM
Default RE: air filter cleaning
Hey man, I use some stuff I bought at the bike shop. One is a cleaner and one is the tacky oil spray. I have to say that the cleaner is simply amazing.
Old 11-18-2007, 08:32 PM
dirt_beaver's Avatar
When i clean my uni, I pour a little gasoline in the bottom of a bucket, roll the filter in it, and then dry it off. It cleans it really well. Then i use the same PJ1 filter oil deej has picted above to re-oil it.
Old 11-18-2007, 09:07 PM
kawikathy's Avatar
PJ does work great. I also use it to kill the scorpions in my garage with, works better then anything else I've tried
Old 11-18-2007, 09:19 PM
ORIGINAL: kawikathy
Scorpions!!!!!????? I just got one of those all over body shivers. Man I'm glad I live in a place without anything like that.
Old 11-18-2007, 10:24 PM
OMalley912's Avatar
Check out part washers at Northertool.com You can pick up a small 10 gallon for about 70.00 bucks. It has a small pump that generates clean solvent through a filter. Will save you money in the long run if your constantly cleaning parts.....deej
Old 11-18-2007, 10:33 PM
OMalley912's Avatar
worth the money down the road
[IMG]local://upfiles/5158/1C8AA555D8154F268B2EB3B34549F685.gif[/IMG]
Old 11-18-2007, 10:43 PM
chris72a's Avatar
Hey the Frog,
I've been researching this as I have not cleaned mine yet, only had the bike a couple of days
found this link might help or might not.
Cheers
Chris.
http://www.transworldmotocross.com/m...075734,00.html
Old 11-19-2007, 12:45 AM
neanderthaler's Avatar
haven't had to clean my air filter yet either, just got the bike 10/01, haven't been in much dust or mud yet, but i still have the twin-air cleaning kit from my old kx. it has two buckets, one is a smaller bucket you fill with twin-air cleaner and it has a tray to keep the filter off the bottom with the dirt. lightly wring out the filter, and dip it in the second larger bucket filled with twin-air filter oil. again, lightly wring out the excess oil and you're good to go. filter cleaning was such a "p.i.t.a." for me i always thought it would be a great idea to invent a pre-oiled disposable filter, and now that i'm back on a dirtbike i see a company called ready racing has just that. i'll do a search and see if one is available for our bike.
Old 11-19-2007, 09:04 AM
danielsan's Avatar
Petrol is not good for the airfilter - over time it makes it degenerate. Apart from labelled cleansers from a bikeshop use Mineral Turpentine otherwise known as Turps. It is not as harsh as petrol. Dont forget to wash the filter in warm water afterwards - do not wring out, but rather 'scrunch' with a dry cloth to get the excess water out.
When i bought my unifilter it came with a 'waterbased' clenaser - i havent tried it yet.
Highbeam
09-09-2022 11:26 AM
Savagekilla
03-20-2009 08:42 AM
Steve Ninja Strombol
Ninja 500R
05-13-2006 05:52 PM
Quick Reply: air filter cleaning
