Air Box Lid Removed = Safe ?
#31
I have the KDX snorkel and its rejetted w/ Big Gunn exh runs well with no water problems...and I have run real deep a couple of times.
"Lid off" was too much seat of the pants noise with no noticable gains, if I ever get around to finally do the 351- I might try to cut the top and fit another snorkel.
#32
A bit of rubber installed vertically around the top of the air box is something I was considering as well. Keep out the splashing and dirty water a bit better perhaps. There is some vertical room under the seat that would ordinarily be taken up by the snorkel.
As an update - the drain tube from at air box bottom was plugged with dirt and probably air filter oil so water was not draining from the bottom and probably causing the intermittent stalling. Bike ran rather well considering the puddle of muddy water.
#33
Quiet the open airbox?
Just bought an 06 KLX250S a few weeks ago and just found this site.
Mine came with an FMF Q4 muffler and KLX300 head pipe (I'm told), a K&N filter and (again I was told) a Dynojet Stage 2 kit (125 main jet maybe?).
The airbox lid was removed when I bought it and yes, I do hear a lot of intake noise from the box.
Is there any mods to quiet down the intake w/o losing the airflow?
Thanks...
Thanks...
#34
Thanks...
Thanks...
I run a 331 big bore with webcams & get enough air flow on my bike with a bigger snorkel fitted (something like a KDX200)!! Guys with 351 bore kits get enough air as well by doing this. Removing the lid on a 250 is just noise for the sake of noise IMHO.
#36
Thanks...
Thanks...
#40
Hey matt, I too get the miss.... same spot on the tach... doesn't always happen but is more common with the airbox lid off and at WOT.... this is what initially led to my question of float bowl adjustment in another thread.
spark? timing? the questions never cease
