Air box detail
Old 08-06-2014 | 03:05 AM
Richard Avatar's Avatar
An update on using the NGK AFX a/f meter
I just finished tuning the XR200 with the a/f meter, and got it so very close without even taking it off the stand You guys need to get an a/f meter and pass it around or something..
Here's how it went today..
Picking from last time I worked on the XR, I took out the 42 pilot jet and put in a 40 and whoops the 'box' says waaay to rich..what the heck happened?? I take it apart and ahh I see... I'd misread it and put a 48 in by mistake! ..I probably would have been riding around with that 48 in there for how long trying to see how it felt etc ..BUT relying on the box, I took it apart and spotted wrong sized pj inside.
So in goes the 40 pilot jet.. a little leaner fuel mix down low than with the 42 and a/f ratio now in the 12s, but too lean as I rev it some-in fact popping as the revs get higher and the box is reading above 15:1, so I richen the needle one notch and BINGO it's looking good
I finish it off by richening up the idle mix a little and I'm a happy camper. Still need to do on the road WOT testing though; and of course more tuning on the Kawasaki
- Best thing since sliced bread. It saved me a ton of time and effort. Next report will be on the Kaw
Old 08-10-2014 | 11:42 PM
Klxster's Avatar
Hey Richard, lets go buddy.. We need some actual AFR's on that TM36-68 as well as the difference the insert makes.. I want to buy the carb but I will not tune it based on opinion and conjecture without any actual numbers to back up the suggestions. I thought the DJ stage 2 was perfectly fine as the bike ran great - Dyno AFR chart showed just how wrong I was.
I'd like to do the same with the TM36 if you can get me in the ballpark with your AFR meter and settings... OK?
Old 08-11-2014 | 03:28 AM
I'm on hiatus for awhile.. my recent gains have satiated my need for speed it seems. But I may wake up one day and give it a go
Muttgrunt
04-20-2009 01:53 AM
markturbo
10-25-2006 05:10 PM
djen223
08-25-2006 08:20 PM
flyboy110b
02-16-2006 01:44 AM
a16tony
01-21-2006 06:43 AM
Quick Reply: Air box detail
