AHL 300cc installed
AHL 300cc installed
I finished up the AHL kit install yesterday with the installation of some Xitomer radiator guards from Amazon.
The bike starts and idles beautifully, so the initial break-in run will be this afternoon.
I kept the 250 cylinder and piston safely stored in case things go awry and I need to swap it back in.
This was a new experience as I have never been this far into an engine (unless you count the lawnmower I "fixed" in 1973--and I don't). Lots of challenges to figure out and overcome. Fortunately, most motorcycle forums have a bunch of people willing to offer advice and encouragement.
I'll post a follow up when I get the ride completed.
I spent about 25 minutes just wandering around connected subdivisions running the revs up and down fairly gently. The bike pulls well and feels strong--how much stronger is hard to tell since I last rode the 250 version in late November.
No weird smells or unexpected smoke, so I guess time will tell whether it is all good or there is a hidden problem.
I'd say give the AHL kit a try if you have any mechanical ability. I have none and I seemed to have pulled it off.
Newer kits are plug and play. Recently installed kit. Was prepared for tensioner modification. But everything was bolt on!
I had forgotten about the tensioner issue and ruined one trying to install it. Got a new one and cut it down so it fit. Good thing I ordered when I did as the spring is now on back order. Partzilla says 200 to 210 days for delivery.
