Aftermarket blinker/light switch assembly
A little off-trail foray through a clump of small aspens destroyed all the controls on my left side handlebar, plus the blinker and the fork shields. I think I can source out aftermarket replacements for everything except the blinker/light switch assembly (is the horn on there too? can't remember - never used it). Any thoughts on replacing it? Thanks in advance.
http://www.bikebandit.com/houseofmot...-2009/o/m17954 its only $60 bucks for a new one. i looked up 09 but you can change if needed
Yeah, I looked on BikeBandit and the actual price for the LH control, the one that works the lights and blinkers, is $83 for the '07 and $84 for the '09. The RH side costs $60. But thanks. Looks like I may be going OEM but thats quite chunk of change for wee plastic housing with some wires and contacts. Maybe I can just wire mine back up, tape it up, and hose clamp it to the handlebars. It's still mostly intact but the housing's busted and a wire or two is pulled loose.
Hey, thanks again for the response bmx!
09, 250, aftermarket, aftermarketblinker, blinker, blinkers, kawasaki, klx, light, lights, mule, rear, replacement, side, switch
