Adjusting Front Fork Damping Question
This may sound stupid but it's what's kept me from actually doing this, on the front forks at least.
Clockwise from who's perspective? If I'm underneath looking up, it's not the same as top looking down and screwing from teh bottom...
How to do it
Then as I look up from the ground at the left or right fork (flat screwdriver in hand)
I turn the set screw clockwise until it is seated.
Then back it off the specified number of clicks to get the damping you desire.
Be sure that they are the same on both sides.
Go a little softer in dirt and firmer on road IMO.
It's nice to be able to adjust this stuff quickly depending on the days ride ahead.
Remember Lefty Lucy...Righty Tighty (unless you're dealing with reversed threads of course) which is not the case with the KLX250 forks.
The Kayaba forks used by Kawi for the KLX250/300/250S will require revalving if you ride them hard. For some reason, Kawi designed the high speed valving is too stiff and the low speed valving is too soft. The bike needs to have a more moderate high speed valving to absorb whoops and rocks, and a stiffer low speed valving to prevent bottom-out. Of course, this should be adjusted after you have the correct spring rate for your weight and fork oil for the type of riding you do.
There is only 16 clicks on the compression adjustment, and as for the rebound there is no adjustment all that you do for the rebound is lift the bike so the front tire is in the air and remove the brass screws on top of the fork tubes give them time with the screws out so they have time to equalize with the atmospheric pressure and then replace the screws. this info can be found on page 124 of the owners manual.
ken
ken
Front Fork Adjustment
Actually I started this thread to ask if I should be concerned that my left side adjustment screw at the front fork is VERY hard to turn and DOES NOT CLICK.
I know about the adjustments, but I thought there might be a problem with the left fork if the adjuster does not operate smoothly and without clicking.
Any thoughts on this?
