Added Zeta Hand Guards w/signals, pics
Still on my quest to "clean-up" the front of the bike. I added the Zeta Hand Guards with Turn Signals and removed the stock turn signals. I'm not to sure on my color choice of Hand Guards (orange), or if the LED turn signals are going to be bright enough, to stop somebody in a large suv texting and eating from running me over. Zeta does sell the LED lights separately, that I might add another set next to factory set. I did buy the resistor from zeta and added it inline.
This is step 2, step 1 was last week adding pro taper bars. I've re-adjusted the hand guards about 3 times now and after looking at pics, it seems the right side is higher.
I'm still waiting for hand guard mirrors and grips to come in from Motostrano. Should be in next Wednesday.
Here's some pics...
Here's some pics...
Looks good, I seethat you put the rim tape in orange on too, I bet the bike would look cool if you pit some other orange stuff on it too. Like chain, sprockets, and guards, specifically the rad guards, I painted mine black.
'Inline,' as in 'series?'
I hope not. Maybe you're just using the term loosely. Just to make sure though, the load resistor should go from the positive wire to ground...not 'inline' with any single wire. Otherwise you're just dimming the signal and not slowing down the flashrate.
ZETA PROTECTORS MOTOLED RESISTOR WIRE (Pair) - eBay (item 140524018696 end time Mar-22-11 22:19:04 PDT)
The Zeta resistors have a positive and negative leads.
Just ordered the Zeta handguards with signals. I also got the resistors. Got a good deal on ebay. $100.00 for the guards and the protectors. I'll post pics when I get them installed. I got the black protectors. I felt you would be able to see the signal better.
The mirrors came in last night, not sure if they are the look I was hoping for. So I ordered some mirrors off ebay that stick on and can be rotated 360 degrees.
I got the same deal on the hand guards on ebay.
Anybody have any input on the edge tailight, as far as being seen ? The front turn signals are one thing, the brake light is another.
MaximusPrime
06-24-2012 04:30 PM
