Acerbis 3.7 tank reviews?
#31
2009+ Acerbis Install Photos gsnorcal
This may also help ya'll with 2009+ bikes. It was a link I found on justgastanks but I don't think it's there any longer. It's quite a gallery of pics with some descriptions.
http://gsnorcal.smugmug.com/gallery/5326416_wmUMY#!i=325389480&k=MEAFG
#33
You know...this is probably true. Once you get to know your bike's performance as it relates to fuel mileage in a given set of conditions, you can pretty much just watch the odometer on super long rides. I've considered doing just what you did, as I have more of a fear of stalling out on a really long, sketchy, technical climb just as my fuel level hits that reserve tube. I can see my fuel level, and I can see my odometer, and I can pretty much project how much farther I can go at any given time. I'm fairly amazed at how predictable my bike's fuel mileage is under a variety of conditions. Of course, I also realize that my petcock and standpipes are probably going to have plenty of fuel during a climb, but on a long epic ride in CO or UT, that niggling thought always enters my mind. If I weren't such a lazy jerk, I might just put my petcock lever on reserve to start with and forget about it. But as a lazy jerk, I just hate turning that petcock an extra 1/4 turn every time during first start-up for the day.
#36
So my next question, this tank hold .7 more than the IMS and is 45 bucks cheaper. The install looks simple. The looks aren't so great, but 45 bucks and the extra fuel add up to make it tolerable. Is it possible to get the fuel out. I've heard rumors of having to tip the bike etc... What's everyones experiences as far as 09 goes.
#37
#38
Ricky:
Good review. I've only ran out and needed reserve once. It started up fairly easy for me after the switch. I have a little clear fuel filter between the petcock and tank and looked there to see fuel moving though after turning petcock to reserve. Once fuel quit moving (carb bowl full), I hit the starter and it may have taken a few seconds before it fired. My petcock is difficult to turn (is there something that can be done to improve this? can it be lubed or something) and I can't get my had under there while moving to switch 180 degrees from on to reserve.
They do make clear or translucent fuel lines, but these are often a specialty item and not generally stocked in the auto or m/c shops that I frequent. I like using them on the snowmobile to see if fuel is moving through as sometimes ice will form in the line, blocking flow. Pull the rope all day long and she won't fire up! I think you have it right and the line provided with the Acerbis tank is for the fuel cap vent, not fuel line.
Either way I take turning it seriously as it is hard enough I fear I may break something. With the stock petcock I could do that while riding - I probably will be able to do this while riding with some more practice.
#39
Acerbis 3.7 Tank Reviews?
In my opinion the Acerbis supplied petcock does not turn as well as the std. KLX250S OEM part. Could be the Acerbis part is not made as well as the OEM and binds up when used after awhile. Ethenol mix gas??? Try taking it apart and cleaning and then reassemble using silicone spray to lube the o-rings. I personally like the IMS 3.4 gal tank that uses the std. Radiator shrouds and OEM petcock. Price is around $270.00 at various U.S supply places. Comparable to the Acerbis price, but uses the OEM shrouds for better radiator support in a fall. I have gone 175 miles before reserve so far on the IMS. My 2009 KLX 250S has a jet kit and a 122 main jet, FMF "Q" slip on SA muffler. Stock except for removing the airbox cover and enlarging the engine breather hole in the airbox to 7/16ths in. I also use Motion Pro grey fuel lines. I think they are nitrile based and are not effected by the "New" Ethenol fuel mix we now get in our pump gas. Try these they work great after 3000 miles of So Cal desert riding.
Also an oz or two of Lucas Fuel treatment helps clean out the ethenol crud in the carb and petcock as well.
#40
I beg to differ. The Acerbis tank is much tougher and offers far more radiator protection than the stock OEM shrouds.
