Accessorizing the KLX
Old 06-16-2006, 09:39 AM
bryantjt's Avatar
Default RE: Accessorizing the KLX
I use the peg approach when I'm leaving the house and when I'm on pavement etc, in the dirt on the other hand the trails usually have enough of a track worn in that I can stand off to one side and get on fine
Old 12-09-2006, 10:41 PM
double d6's Avatar
Thanks for that pump placement idea. I just recently had a flat that I inflated without the need for a new tube or patch, strange thing, it went flat, I pumped it up and all is ok--so far.
This little pump while hard to use will definatley give me a better feeling until I order the Co2 gun.
Plus like you said, it's great to let out a little air and be able to fill back up before hitting the roads.
I used the same place with a different mount.(all plastic wire ties)
Dave
Old 12-10-2006, 12:23 AM
bryantjt's Avatar
Wow, old post, I took that pic 2200 miles ago!
Old 12-10-2006, 03:31 AM
DirtSurfer's Avatar
My friends and I are on sand, then road at 45 to 55 mph then sand again etc.
I use this 12 volt pump:
http://www2.northerntool.com/product..._200328573.htm
Its compact, inexpensive and it attaches directly to my battery recharger hookup wire. I can get from 10 psi to 22 psi in about 20 seconds each tire.
turbomaniac
03-24-2011 07:15 AM
jespo
02-01-2008 02:14 AM
DirtSurfer
02-17-2007 05:09 AM
Bad Bear
07-24-2006 12:59 AM
incabiker
07-03-2006 10:56 AM
Quick Reply: Accessorizing the KLX
