Abducted by UFO on KLX
Is this normal - after I replaced the #35 pilot with the #40 I never need to use my choke. The bike always fires up within the first crank (okay, almost all the time). If I try and use the choke the bike WON'T start. What gives?
RE: Abducted by UFO on KLX
The choke basically starves the engine of air to richen the mixture for starting, right? So maybe with the bigger pilot jet the choke is making it too rich? No air = no fire. I dunno, my bike is stock and I need to use the choke everytime I start it cold. I'm also only about 200 feet above sea level. I personally wouldn't complain about never needing to choke it. You risk angering the kawasaki gods.
Brian, that sounds about right - maybe I should go with a #38 pilot?
mmatz, I was hoping the aliens would take me to Pagosa Springs, the heat here is driving me insane. Almost bought a house in Pagaso back in '94.
ORIGINAL: klx250s_rider
BTW, what is the issue here? Are you having problems starting when the engine is hot?
Good question - what is the issue here? Just feels like it's running too rich - maybe it's just the heat in my helmet baking my friken brain bub! I'll turn the FS in a half turn and take it from there.
