98 klx300 cylinder on 06 klx250s
Old 07-09-2013 | 11:10 PM
1994klr250's Avatar
Default 98 klx300 cylinder on 06 klx250s
I looked at various websites to see if a 1998 klx300 cylinder would fit on my 2006 klx250s. They all show they are different part numbers due to the 300 vs 250cc's. I have a chance to buy one from a friend but I just want to be 100% before hand. Is it a direct swap? Thanks, Fred.
Old 07-09-2013 | 11:26 PM
Karitane Pete's Avatar
Check on the web that the base gaskets are the same, some of the 300 barrels (early ones) are a different outside diameter were they fit in to the crankcase.
Old 07-09-2013 | 11:32 PM
1994klr250's Avatar
Just did a quick check and the cylinder base gaskets are the same part numbers. So it looks like its a good match. Thanks for the help, Fred.
Old 07-10-2013 | 12:36 AM
The problem with 300 cylinders not fitting some 250's was based on the older...back in the 90's...crankcase opening on the older 250's being a touch too small to fit the 300 cylinder extensions into the crankcase.
Lutz
10-21-2011 06:35 AM
FlyingFinn
10-10-2010 11:49 PM
KLXelent
10-10-2008 02:09 PM
shox rox ice
02-08-2008 12:33 PM
dbdanny
02-06-2007 05:43 PM
Quick Reply: 98 klx300 cylinder on 06 klx250s
