7500mile prep work
Old 10-31-2006 | 04:15 PM
a16tony's Avatar
Default 7500mile prep work
I'm getting ready for my 7500miles check up this weekend. What has been the weak spot on the KARC? How much valve wear should be expected? I hope they are in spec, I set them at the loose end of the scale. And for those interested, I have ordered a new stock countershaft sprocket. With 6100miles on it, it looks terrible. I had to change the DID chain last weekend with 6700miles on it, very worn. Please let me know if there are issues that you have come across that I should look at.
Old 10-31-2006 | 04:21 PM
Default RE: 7500mile prep work
Hey Tony - if I were you I'd go ahead and replace the rear sprocket as well. The chain, front, and rear sprockets tend to wear together and all will last longer if replaced together.
Old 10-31-2006 | 05:22 PM
You might take the steering apart and check out those bearings. That is if you washed it every week during the summer like I did.
Old 10-31-2006 | 06:01 PM
a16tony's Avatar
+1, in process.[sm=smiley20.gif]
Old 10-31-2006 | 06:03 PM
a16tony's Avatar
ORIGINAL: deej
+1, done, used marine grease
maninthesea
03-02-2010 04:59 AM
Phil2801
Ninja 250R
16
11-06-2007 09:30 PM
lefecious
04-15-2007 05:21 AM
tremor38
11-28-2006 02:19 PM
bryantjt
09-13-2006 02:04 AM
Quick Reply: 7500mile prep work
