7465 Mile Valve Check
Old 11-03-2006 | 06:20 PM
Marty's Avatar
Default RE: 7465 Mile Valve Check
ORIGINAL: a16tony
ORIGINAL: EMS_0525
what are you using to check them... i bought feeler guages but they are in inches...
My feelers(crastsman), show .000 inch and .000 mm
Dang, I must have bought the wrong set - mine don't go as low as yours! I mean .000 is small!
Old 11-03-2006 | 06:47 PM
a16tony's Avatar
[/quote]
[/quote]
Smart *** Floridian.........[sm=bustedsign.gif]
Old 11-03-2006 | 07:26 PM
charleshmosesii's Avatar
7500 miles on your klx, you kick ***!!!!!!!!!!!!!
Old 11-03-2006 | 08:45 PM
CRT_Leech's Avatar
ORIGINAL: a16tony
ORIGINAL: EMS_0525
isnt the range from .15mm to .19 mm on one of the cams? im not sure how to measure that that precise to see what exactly it is... say i tried using the .15mm guage and its too thin, so i go up to .20mm gueage and its too thick how do i know exactly what the clearance is?
intake: .100 - 190mm/ .10-.20 basicly, so if the .15 fits and the .20 doesn't, your right on. If the .20 fits in between...too loose
exhuast: .150 -240mm/ .15-.25, .25 should never fit, .20 is your goal.
I that a better answer?
If your gauges have increments in between, you could add two or more together to come out to the range you are looking for, as well, double-checking to make sure that it's still not too much, with the top end, single guage, for example, the .20mm for the intake. Just make sure they are really clean, so as not to add any additional clearance due to grime, grease or dirt.
Old 11-04-2006 | 01:44 AM
Nice job, Tony!
Beardoge
07-15-2013 11:27 PM
kgwld1
12-12-2008 12:37 AM
Ginsu4u
KLX125 & KLX125L
09-10-2006 09:49 AM
ntloser
09-03-2006 05:45 AM
incabiker
03-26-2006 05:10 AM
Quick Reply: 7465 Mile Valve Check
