51t rear sprocket
The klx300 is 14t - 50t, maybe you can take chain guide from this bike?
On mine I kept rear stock but went down 12t in front. It did rub the case just a tiny bit, now it's fine. The 11t doesn't fit.
I might try that. My chain rubs but with no tension it sits on the lower guide
Kmarts - welcome to KF!
You may find this thread useful: https://www.kawasakiforums.com/forum...-length-42553/
I'm running 13/51 & 14/51. At 14/51, my snail adjuster is at -0.5 with a 110-link; there is absolutely no adjustment remaining to get the axle closer to the swingarm. With a 112 link chain, 13/51 was maxed out on the adjuster as far as it would go. I like switching between 13 and 15 front sprocket and am therefore not really pleased with a 51 rear because it doesn't work well with both fronts for either 110- or 112-link chains.
This climb with the 13. Skip to 14:50.
