45-tooth rear sprocket nearly non-existant
Old 10-25-2006 | 08:59 PM
Default RE: 45-tooth rear sprocket nearly non-existant
Hey Iowa glad you like the rear turns, I actually got the idea from Gravy Train, here is where I got mine. There are several to choose from, but I wouldn't recommend the smoke colored ones because we need all the help we can get. Later man.
http://www.motorcycle-superstore.com...661&division=6
Old 10-25-2006 | 09:18 PM
i like the smoke ones.....
Old 10-31-2006 | 07:06 PM
ORIGINAL: Iowaguy
well, i got the 45-tooth rear sprocket yesterday. i installed it onto the rear hub and then attempted to put the rear wheel back on and found out that the oem chain WILL NOT fit the 45-tooth rear sprocket. it is way too short so i now have to get a few extra links.
Yea I was wondering about that, plus you need to allow for suspension drop which will make the chain tighter when under a load. Its funny, one of the first things I bought after I got the bike was the new Fox Tracker boots, gloves, the 13 tooth front sprocket, and a chain breaker. Not sure why I got the chain breaker, since I have never used one, but maybe someday I will. Also in case anyone didn't know you can flip the adjusters on the rear wheel so instead of running out of adjustment because the long arm is hitting the pin on the swing arm, if you flip or reverse them, the adjustment will be down instead of up.
JasonFMX
09-28-2008 04:11 AM
07 KLXER
06-12-2008 01:14 AM
bryantjt
11-02-2007 04:53 PM
dazjr
08-17-2006 06:48 PM
