351 octane
Old 04-23-2012 | 02:31 AM
2007 Green Machine's Avatar
Default 351 octane
So, what level octane of fuel is everyone using with their 351?
Old 04-23-2012 | 03:21 AM
jhoffy22's Avatar
I use 93. I don't know that it is necessary but it's what I have chosen to use.
Old 04-23-2012 | 03:39 AM
RaceGass's Avatar
The compression ratio increased abit over stock I was told, and with the stock set up running hot enough to turn the header blue I have been running 91 octane. Hopefully it helps run abit cooler too.
Old 04-23-2012 | 03:42 AM
jhoffy22's Avatar
Stock compression ratio is 10:1. 351 compression ration is 12:1.
Old 04-23-2012 | 04:48 AM
LikesToThump's Avatar
My manual quotes 11:1....
Old 04-23-2012 | 05:09 AM
wildcard's Avatar
i don't have a 351 (331 instead), i run 87. No detonation so far.
If it starts knocking on 87, go up to the next octane level.
Old 04-23-2012 | 12:43 PM
Blackheart58's Avatar
Exactly my setup and choice....and there are times I ride at temps exceeding 110 F!
Old 04-23-2012 | 04:57 PM
Ok. Thanks everyone I guess I'll go with 87 and see what happens.
Old 04-23-2012 | 05:11 PM
CousinLarry's Avatar
I've been using 91/93 since day one with my 351 and it runs good.. Never tried lower, maybe I'll try next tank as a Mr. Wizard science experiment..
I just figured higher compression would benefit from higher octane.
Spinner
Ninja 500R
08-22-2006 05:23 AM
NavKLX
01-26-2006 08:42 AM
MAD KAW
09-15-2005 11:45 PM
MAD KAW
08-17-2005 01:25 PM
TATTOOZIT
06-21-2005 04:44 AM
Quick Reply: 351 octane
