351 kit without the carb.
So who has the 351 with out the carb mod? Does the kit work just fine without the pumper carb? I'm going to get the kit for my SF but can't swing the carb right now.
also are you running snorkle, no snorkle no lid? I have the lid removed on my SF due to only riding street with no water crossing.
Yes the 351 works fine with the stock carb. I had that setup. I have the KDX snorkel because I don't like the noise. Torque is the word!
I went from weed whacker to thumper when I put the big bore kit in.
David
David
+1 stock carb here, no plans on a pumper. With propper jetting the stock carb is plenty big enough. They sell much larger jets for my CVK than the one that are in it now. From all I have read the only advantage the pumper has is quicker response.
Dan
Dan
What's the proper jetting? Stage 2 ? Reason I ask is cos i want to go with a 351 but can't swing the pumper either.. (the wife will just kill me)
I have about 75 miles on the pumper. I put 400 miles on the stock carb with the 351. The pumper is different. Response is "crisp" to say the least and its anywhere you turn the throttle. I would not put one of those quick turn throttles on with this carb.
I DID get rid of a 6500 rpm flat spot or misfire or bucking or what ever you called it.
Since the pumper I keep looking for 7th gear.
You are going to love the 350!
I ended up with a 132 main in the stock carb and it was just right.
David
David
Dan
I idled it first till it was warm, shut it off. Checked the oil and antifreeze, drove it to town being nice. After 70 miles I changed the oil and started to find out what was really there. Its now 500 miles and It seems to run better and better. Some times I think its still breaking in. Since about 100 miles on the motor I figured it was broken in. Steel liner breaks in pretty quick. Top ring is chrome, center one is cast. The liner was honed just like the picture in the textbook.
David
David
jhoffy22
06-18-2011 12:17 AM
