350 cc big bore for KLX250
Old 11-13-2008, 12:53 PM
b_joannblue's Avatar
The 350 kit will be 351.3 cc
  #32
Old 11-13-2008, 01:09 PM
yorgomiami's Avatar
Very cool a 351 Cleveland for my KLX. Those were the days.
  #33
Old 11-13-2008, 08:48 PM
kgwld1's Avatar
Due to the increased suction of the bigger bore a drop in jetting will be required.
  #34
Old 11-13-2008, 09:37 PM
tremor38's Avatar
That one passed above my head. Can you enlighten me on what that means, Sir?
  #35
Old 11-13-2008, 10:26 PM
kgwld1's Avatar
From the increase in bore size you actually get more pumping draw and actually have to drop the main jet size due to the cylinder will actually pull more fuel out of the jet so you will get a rich condition instead of lean.
  #36
Old 11-14-2008, 06:55 AM
tremor38's Avatar
Ok, I should have read your original post more closely. I thought I had read 'drop-in' jettting, when you actuall wrote 'a drop in jetting' (no hyphen).
My mistake; makes sense now.
  #37
Old 11-14-2008, 11:56 AM
thats interesting.... you have the 340 kit right? did you have to do this for that cylinder?
  #38
Old 11-14-2008, 12:48 PM
kgwld1's Avatar
Yes I have a 340 and had to do this. When ever you increase V/E on pulling side (piston) you will have to do this. This doesn't apply to uncorking the stock cylinder due to how bottled up they are from the factory.
  #39
Old 11-15-2008, 02:44 AM
tremor38's Avatar
How's the G450x holding-up?
  #40
Old 11-15-2008, 03:16 AM
kgwld1's Avatar
I'm thru the 20 hr service now and run it on the 51 hp setting its a monster. I've got it apart doing some stuff for the spring the engineering on this thing is pretty impressive.
Quick Reply: 350 cc big bore for KLX250
