340 Results!
Old 07-14-2007 | 11:07 PM
kgwld1's Avatar
Default 340 Results!
Well did it in about 3 hours. Everything went fine then putting the tank on I broke one of the cheap gas lines, so I thought fine I'll just go and buy some bulk line.! Wrong, well it was not bendable enough and hit my new 36mm carb so I had to make it work. Well rushing to get it done I drove a bolt with a ImPACT THRU THE STOCK TANK MY DAY WAS sh*t after that. Well I did ride it around the block quickly before I saw the hole. I still have the stock pipe (I'm waiting for my aftermarket one), anyway it had lots of pull then a big bog so I'm sure rejettings in order but I'll wait for the pipe. It did pull the front wheel up fast before the bog. Oh well. My new clarke tank was just ordered. I'll keep you updated on the bike.
Many beers will be had tonight, Kevin
Old 07-14-2007 | 11:30 PM
Default RE: 340 Results!
Hey Kevin, sorry about the tank, but since you are getting the other one I guess its all good right? Sounds like you had some fun today. I would substitute the beer (because I hate the taste of beer) with Gin and Tonics, a Screwdriver or really any drink that disguises the taste of alcohol.Mmmmmm Fruit drinks.[8D]
Old 07-15-2007 | 01:11 AM
tremor38's Avatar
ORIGINAL: kgwld1
Good idea. Open-up your airbox as well. The combo of aftermarket pipe and open air box just might do the trick...if you aregetting a 'rich bog.' It's hard to tell thedifference until you play around some.
Corrected (edited)from 'lean to rich.'[8D]
Old 07-15-2007 | 01:23 AM
MaverickAus's Avatar
ORIGINAL: deej
Hey Deej ever tried an Orgasm? ... its a drink .... really it is [8D]
Old 07-15-2007 | 02:18 AM
kgwld1's Avatar
Air box is already open.....!
Old 07-15-2007 | 03:10 AM
kgwld1's Avatar
340 piston vs 250 piston.
Old 07-15-2007 | 01:38 PM
Beardoge's Avatar
Don't like beer? disquises the taste of alcohol, why drink it then, what are you a girl?
LOL[sm=alcoholic.gif]
Old 07-15-2007 | 11:29 PM
ORIGINAL: kgwld1
ah, that is what the pic was supposed to represent! hahaha
Old 07-16-2007 | 12:57 AM
kgwld1's Avatar
resized pic
Old 07-16-2007 | 01:23 PM
tremor38's Avatar
Cool, then you just need to see the effect of the pipe. Hopefully that will do the trick. Good luck.
ORIGINAL: kgwld1
Quick Reply: 340 Results!
