330 kit arrived
Old 02-28-2007, 03:28 PM
Kawi Wawi's Avatar
Default 330 kit arrived
Thought I'd post some pics to make you all jealous... Kidding.
Actually, I have some questions for those that have done the 330 upgrade from Kustom Kraft. So... Question for you Brian.
The piston I received appears to be a custom ordered unit from JE pistons.
A couple things about that concern me.
1. Is the shape correct (valve pockets, flywheel cutaway, ring grooves, etc)
2. Does it weigh any more...
The first thing I thought when I picked up the piston is "man, this is heavy". It weighs 240 grams or 8.5 oz.
It also came with the spec sheet from the manufacturer, which leads me to believe that Marvin had the piston custom made. What kind of piston did you get Brian?
Old 02-28-2007, 03:44 PM
cwgoff's Avatar
Default RE: 330 kit arrived
Jason,
I can't help you with your questions, but I can say that that there is one purdy set of parts. Congrats!
Chris
Old 02-28-2007, 04:33 PM
Yeah, that's the same piston I got. I seriously doubt it is custom. The label on the box for mine says "L.A.SLEEVE J5339PS" and on the piston itself it has the JE part number as shown in your photo above. I don't know how much heavier it is. I still have my 72mm piston from my 249cc so I guess I could wiegh. I'll try to do that this evening maybe.
That sure is a great looking piston, though, isn't it!
Old 02-28-2007, 08:29 PM
markturbo's Avatar
Are you going to use the stock carb with it? Let us know how it works! If I can't sell my bike this will be myother option.
Old 02-28-2007, 09:00 PM
Kawi Wawi's Avatar
Thanks nobrakes! Yep, stock carb for now... Life is a little busy round here so it'll be a while before she's all together. I plan on doing lot's of stuff all at once (valve adjust, big bore, grease head bearing and swingarm, t-mod for carb vents, adding power cable for GPS, new tires, rimlocks, etc, etc).
I'll be sure to take lots of photos of everything and post them here!
J
Old 03-01-2007, 02:32 AM
Kawi Wawi's Avatar
whatcha waitin for? git that jug over to marvin and join the "330" club! [sm=icon_rock.gif]
Old 03-01-2007, 03:24 AM
Bake's Avatar
That's the 330 piston I looked at , with the LA Sleeve work he had done while at Bill's last weekend. They are very trick.
Old 03-01-2007, 08:47 AM
mooredan's Avatar
My jug is on its way from ronayers. I won't even take it out of the box, but am shipping directly to Marvin. How's that for following orders?
Quick Reply: 330 kit arrived
