300cc big bore & Dynojet users only
To those who are at 300cc & running the Dynojet kit did you go with the DJ128 or the DJ132? What elevation/intake/exhaust. Again, only if you are at 300cc. Thanks
RE: 300cc big bore & Dynojet users only
I'm at 6oo' above sea level, k&n filter, free mods, 300cc, two brothers with p-3 quiet tip. DJ needle 2nd slot 21/2 turns and stock pilot. I tried a 130 main, but the plugs pretty light. A 132 should be close, maybe one larger. It' such a pain to change I haven't done it yet.
I am at less than 1,000 elevation, I use what the instructions on the kit says, 132 main and 4 th clip on the needle works fine. Iam also running two snorkle cut outs on the airbox lid, works great this way. Just a slight bit of soot at the tail pipe tip, this means just a tad rich. But the soot is barely noticable, iam not a jetting expert so maybe this is just right, better a little rich than a little lean.
