2018 klx250 running a bit rough after new exhaust
Hey guys. I recently fitted a full system two brothers exhaust to my 2018 klx250. It seems to run a bit rough/jerky now particularly at low speed with occasional stalling at traffic lights/intersections. It's the only mod I've done to the bike. Any ideas? I read on the klx250 facebook page the fuel injected bikes did not need tuning as the bike would supposedly work it out itself. The O2 sensor is connected.
Thanks
Thanks
Thanks
Thanks
Anyway, any exhaust leaks, or leaking, from your work, would cause your problems - and is the most likely cause...
You'll need to go back onto Facebook and ask those
In the meantime, get the EJK fueler and set it correctly for you mod combo - you'll find the correct settings in the instructions and/or on their website for the KLX250..
bigger exhaust on a little four stroke pretty much always gives you a slight low end torque loss, and the two brothers is a pretty big exhaust indeed
tuning helps. i'd rather get a power commander than an EJK, the EJK can only add fuel, and in areas where your VE has decreased due to the new exhaust, you often have to remove fuel from areas to get better performance. the power commander also has ***** so you can experiment, but you can also load a proper table into it. best of both worlds
bump your idle up a little bit and give 'er a bit more throttle when taking off for the time being i'm sure it'll be fine
Yep, you did buy one last year - so did a lot of peeps I hope.. Try doing that now !
P.S. You can't,.. They quit selling them within the USA quite some time ago !
Closed course competition only verbiage, but these guys still sell it.
https://cart.dynojet.com/p-2933-pcfc.aspx
Near as I can tell the only mod that really improves power is a big bore kit. I myself wouldn't go to all that trouble and expense just to make the bike sound better. I would as part of a 351 install on my 2018.
I don't know what you call "really improves power", but a full FMF (etc) exhaust system, lidless airbox, and EJK fueler gives you a "whole new bike" to ride. We don't yet have dyno charts to show whether it's a 15%, 20%, or more, increase in peak power levels but the increases over the entire upper half of the powerband create a whole new animal.
Well, the PCFC is the way to go for peeps like me, but, on the other hand, the folks at EJK have done their homework their KLX250EFI fueler. They've developed settings for the highest performance mod combo (lidless with full performance exhaust system) as well as the lesser mod combos - with good dynobutt reports..
