2010 recommendations
Old 12-19-2010, 08:57 PM
Blackheart58's Avatar
Originally Posted by tankbb
since the brake disk stays on the wheel how does it fit past the pads/braking mechanism? it looks like the the whole brake is on a slide rail-does that mean the whole thing pushes forward when you move the wheel up a bit to get the chain off?-also-can i bend the cotter pin back out to use it again?
The wheel is removed by dropping it down, not raising it. If you don't have the rear end up high enough to drop the wheel down, Push the entire wheel forward to get enough slack to get the chain off...there's enough space to allow the rotor to move forward within the brake caliper, then pull it out rearward. Worst case is you slide the caliper forward a tiny bit...that's one of the functions of that slide mechanism.
Once you slip the chain to the outside of the sprocket, pull the wheel out rearward. You CAN re-use a cotter pin, but, I only do so a time or two. Better to just replace it. Of course, you can use the old one, then replace it in a few days when you get a chance to get a new one.
  #32
Old 12-20-2010, 12:45 AM
Just wanted to make sure that you are clear that while the wheel is still on the swing arm, you pull the axle all the way out of the wheel, and this lets the wheel move straight down and out of the brake caliper. Not like a bicycle where you slide the wheel ,axle and all, out the back. I had trouble along time ago because I was trying to remove the wheel and the axle together (like a bicycle).
Dan
  #33
Old 12-20-2010, 03:41 PM
tankbb's Avatar
i think im goan to pull the back wheel off myself today and just hope for the best-worse come to worse ill bring the wheel in if i dont have any tire iron spoons but i really wanna try to get the wheel off the bike myself.
  #34
Old 12-20-2010, 07:41 PM
tankbb's Avatar
well i got the back wheel off no problem! alot easier than i expected. Im just gonna bring the wheel in to the get the tube replaced tho since i dont have any tire spoons-found a place thatll only charge me $15-still concerned about getting the axle nut tightened ok w/o a torque wrench-but should be ok
  #35
Old 12-20-2010, 07:55 PM
Are you getting mount & balance for $15. Not bad if so. My local shop will mount for $10, but they don't have a balance machine. I give it a little of my own basic balancing with a little lead around the light-end spoke. Don't worry about not having a torque wrench for the axle nut. Just get it tight and put the cotter pin in.
  #36
Old 12-20-2010, 09:32 PM
tankbb's Avatar
ill ask when I go back to pick up the wheel in a hour or 2, but i think its just mounting the new tube/tire-you said theres a way to check the balance myself?
  #37
Old 12-20-2010, 10:03 PM
linkin5's Avatar
I've never ballanced a tire on a dual sport and have never had any issues at all. Also I just use 3 big screw flat screwdrivers and have changed a bunch of tires like this and not had any problems, I'm sure a dull spoon type tool would be ideal.
  #38
Old 12-20-2010, 10:05 PM
put the axle in and spin the wheel, see where it stops. The bottom should be the heavy side. Spin it again and see if it does the same. If so..put some weight on the top and try again until it tends to have balance. This is pretty simple and basic. I wouldn't recommend it for riding your Ninja at 100 mph, but for dirt bike tires most seem to find this method sufficient, although many probably do no balancing whatsoever. Heck, you're on dirt, are you gonna notice a little out of balance?
  #39
Old 12-20-2010, 10:13 PM
wildcard's Avatar
I don't even bother to balance the tires on my sport bike. I just line up the balance dot with with the valve stem and haven't had any issues so far. Don't see why the KLX would be any different though i haven't yet gone through the factory tire (almost there).
If you do have any issues with tire balance though i would get an ounce of dynabead and put those in. I used them once to fix a hack jobbery mount and balance job that a shop did for me (hence why i started mounting my own tires) and the beads balanced it right out. I'm pretty sure dynabead works in tube applications (though i would check and make sure) as long as you don't have slime or something akin to that in the tube.
  #40
Old 12-21-2010, 02:36 AM
tankbb's Avatar
got everything back together alright-drove around the block a few times, everything seemed to be as it was before. not as bad as i expected
TheMaverick
05-22-2007 04:54 AM
cwgoff
01-05-2007 03:33 AM
mugwump
Ninja 500R
01-02-2007 03:30 AM
Kawi Wawi
06-27-2006 01:25 AM
Musicphreak
09-23-2005 07:23 PM
Quick Reply: 2010 recommendations
