2009 rear brake pad hanging after wheel removed
Old 05-12-2014 | 11:33 PM
valval's Avatar
Default 2009 rear brake pad hanging after wheel removed
I took the rear wheel off to get a new tire. I noticed the inner brake pad is hanging down out of position . Is there a way to put this end back in the caliper without taking it apart?
Old 05-13-2014 | 02:23 AM
GBAUTO's Avatar
If the ear on the pad backing plate isn't in the slot on the mounting bracket then I think that the only way to get enough movement would require taking the wheel/rotor off. I assume that you must have slid the caliper on it's mounting pins while the wheel was off-that's really the only way that the pad could come out.
Old 05-13-2014 | 04:58 AM
valval's Avatar
Ya, I slid the caliper back off the swing arm to see how it attached. I guess i shouldn't have done that. I guess i just loosen the pin and put the shoe back in.
Kmarts
03-21-2015 10:53 PM
MaximusPrime
01-01-2014 11:31 AM
mel0526
Ninja 500R
04-11-2008 03:42 PM
FM_Thumper
03-22-2008 04:22 AM
Ninja Boy
01-02-2007 08:41 AM
Quick Reply: 2009 rear brake pad hanging after wheel removed
