2009 KLX250sf headlight and tail light not working
It’s not the fuses and I’ve changed the bulbs I haven’t found any loose wires either only a plug with nothing connected by the fuel switch. The only wire connected to it is a ground wire(black and yellow) I need help!
go to the key switch and start looking. check that the fuses are good and there is power to the key. thats the only place where the headlight & tail light circuits come together so if you have power to the key switch the problem is inside
you'll need a diagram and a meter
