2009 klx250s NEED HELP
Old 08-15-2009 | 02:16 PM
1broncoman!'s Avatar
Default 2009 klx250s NEED HELP
i am receintly a new owner of a 2009 klx250s i just hit 1000 miles yesterday and the battery was dead for the 4th time. i bought this bike 4 months ago , is this normal for a kawasaki? it just doesn't make since that it has done that to me.And also if i could get some opinion on gearing that would help me out to.
Old 08-15-2009 | 02:27 PM
neilaction's Avatar
Nope not normal.
I'm still on my original battery and mines an 06.
Sounds like something is wrong with the charging circuit and that sounds like a warranty thing.
Good luck with it and welcome to KF.
Old 08-15-2009 | 02:46 PM
Not normal unless your accidentally leaving the key on when you park it.
Dealer should cover that under warranty .
Old 08-15-2009 | 02:53 PM
neilaction's Avatar
As for gearing.
Drop 1 tooth from the front sprocket is a good start. 14 - 13.
And its cheap.
Do some searches.
There is a mountain of info to be found.
Old 08-15-2009 | 05:18 PM
I think he meant gear as in what to wear. LOL Welcome to the forums man, the battery should never go dead unless you leave the key on. Do you have a battery maintainer? Also check the battery connections, if they are lose, it will cause major problems.
Old 08-16-2009 | 03:02 AM
MaverickAus's Avatar
he said gearing deej old boy, as Neil said 13 tooth is a good place to start. Mine is an 06 as well still on the OEM battery, so there is a problem with yours that needs fixing.
Old 09-01-2009 | 05:03 PM
bmx_lar's Avatar
mines at the dealer for battery issues. it was charging at 14v, but in the morning i would go to start it and it would turn over good for about the first two revolutions, then it would crank real slow. they told me that they had a special charger that is supposed to bring them back to life but i think its BS. i should hear from them today.
Old 09-01-2009 | 06:15 PM
DSBoomerRider's Avatar
Yeah definitely something wrong there. Warranty should cover the issue. At least it better!
will-dakar
11-08-2014 07:04 PM
mtnman
09-14-2013 02:28 AM
nornalup
06-04-2011 02:22 PM
Dezrider
10-27-2010 05:31 PM
rockrash42
07-17-2009 09:16 PM
Quick Reply: 2009 klx250s NEED HELP
