2009 KLX250s Leaking gas.
I agree, the different position petcock problem didn't make sense so I put more gas in the tank and it came out the overflow on both positions. I had the carb out for jet cleaning but neglected the float and the float valve so its coming out again for a more through cleaning.
there ya go...
double check the float to see if it has liquid in it. buy a new needle. inspect the seat carefully. if its boogered there are things you can try (with varying degrees of success). the good news is it's almost always the needle
