2009 KLX250 Aux. tank is ready
You can see the front lower tank bracket that will hold the plate outward at the lower bolt position. The inner tank bracket bolts to the original side plate position.
All together the tank has 4 bolts attaching it, with a 5th at the side plate.
It could be used as a refill tank to the original tank I guess. A small hand crank transfer pump perhaps. If someone with an FI bike wants to use it in that manner, they could. Hook up your pump via a hose to the petcock, turn it on, and crank away.
The brackets are completely different from the '07 compared to the '09. Same tank, different attachment system.
no, what i was talking about was the rack fitting itself. it bolts to what looks like the same spot that the tank bolts to (i.e. the seat bolt). But the flange on the tank looks like it is at an angle, not flush. So i was wondering if I have that tank, will my rack still be bolted on as sturdy.
