2009 klx 250s Cyclinder issues from piston pin
just an fyi for anyone that has this bike. I just got the 331 big bore done, and when john removed the old cylinder it had score marks from the piston pin scraping the sides. What happened was the hard working mechanics at Kawi decided one Circlip was all that was needed. Even though the schematics show 2, they only installed one. So, had i not gotten this work done my engine could have seized and i would have been SOL becuase warranty was over. I would suggest you bring this to the attention of your dealer and have them pull it all apart before your warranty is over so you dont run into any problems.
Well said. It probably has to smoke like crazy in order for them to even think about it. Any other time, the same response, "Its normal".
I'd say the only way would be if u had one of them snake cams( Rigid makes one) and went thru plug hole to check for scoring of the cylinder. plug hole might be too small tho. Of course if u can hear the pin scraping - give it to her. wont last long! then bring it in.
I lost a circlip in a Montessa engine. It caught in a port tore the piston up and embedded in the top of the piston and the compression dome of the head. Caused quite a mess.
scrtch111
05-04-2012 05:13 AM
pitbull419
09-25-2007 01:28 AM
