2007 KLX-250s Butt Plug Removal
RE: 2007 KLX-250s Butt Plug Removal
You could always take this approach with your stock muffler.
http://i156.photobucket.com/albums/t.../06KLX250S.jpg
ORIGINAL: justanotheradikt
didnt you make that out of scrap stuff? i for one dont have scrap stuff or id def do that...its well out of the way of everything...how does it sound?
well if you got any more scrap...let me know
ORIGINAL: klx250s_rider
Yep! I used a 1/2" drill bit to go through the first baffle, then a 3/8" to go through the second. You're going to need a 12" long (3/8") drill bit to get into the second baffle - I got mine at ACE Hardware, I think it cost me around $17. It sounded and performed a little bit better than stock. I like the sound and the performance gain of my HMF better though. Once you get bitten by the "bug", there's no stopping - so get a couple of extra credit cards and go for it - I can also recommend a good, cheap bankruptcy lawyer!
Maybe! But then again statistics show that 99% of forest fires are caused by 1) lightening 2) campfires 3) cigarettes 4) napalm (of course depends on what country you're living in) 5) squirrels playing with matches 6) logging and last but not least, 7) forest rangers. So don't be too hard on yourself.
From www.planetklx.com:
"The long tube of the 11mm (inside diameter) buttplug that goes back into the core of the muffler is approximately 50mm long. The internal piece on the Krizman drawing that is labled "outlet" or the outlet pipe, which extends both inward and outward from the rear baffle, is already in place internally on our KLX exhausts without the buttplug in place -- as long as you haven't gutted the internals. It extends back inward towards the turbine cone approximately 55 mm - actually further in than the pencil sized buttplug tube, making the pencil tube irrelevant for SA purposes. The turbine throws the particles towards the outside, where they have approximately 55mm before they hit the rear baffle and have to turn around and snake back out the large 35mm hole, which - according to the genius of the Krizman design - won't happen. No steeeenking 11mm tube necessary. This confirms that the only reason for the pencil sized buttplug was to lower the sound level to 82dB..."
"Society is like a stew. If you don't keep it stirred up, you get a lot of scum on top." - Ed Abbey
