2007 Klx 250 electrical prob.
Old 12-08-2015 | 04:04 PM
Skyler Cameron's Avatar
Default 2007 Klx 250 electrical prob.
Ive been having problems with my turn signals, i recently replaced the stock signals with LED aftermarket's and it worked perfectly for about a month, then suddenly when i would engage the signal, all four light up. I tried to track down the issue and discovered that when i unplug the instrument cluster they work again. as well my tach stopped working which is also an electrical component, unlike the speed which is a direct cable. Thoughts?
Old 12-08-2015 | 08:50 PM
rgmr250's Avatar
My first guess would be something shorted inside the instrument cluster. Wires bared and touching, or water got into the cluster and is shorting out a connection?
Old 12-08-2015 | 09:54 PM
Do you think a new instrument cluster will fix the problem?
Old 12-09-2015 | 01:44 AM
MaximusPrime's Avatar
You need a new flasher relay that can deal with the low voltage LED draw.
Old 12-09-2015 | 04:25 PM
I dont disagree but how would that explain why it works when the instrument cluster is disconnected?
Old 12-09-2015 | 08:52 PM
rgmr250's Avatar
If something is shorted in the cluster, when you plug it in, then it's likely shorting something else that's plugged into it.
The only reason I suggest the cluster is that the tach stopped working. Otherwise, I would focus completely on what was suggested about the turn signal flasher unit. Using the stock flasher unit (which is designed to flash at a certain rate, based on the load on the flasher, and incandescent bulbs have a much higher load than LED's), and when you plug in LED's to a regular (non-electronic) flasher, sometimes the signals either flash faster (hyperflash) or don't flash at all (just stay on.)
Do you have the original turn signals? If so, try plugging them in and see if there's any difference - this way you're isolating whether it's an LED problem or not.
Maybe it's just coincidence that the tach stopped working as well, which might be a red herring in the troubleshooting.
Shaunree69
12-07-2014 04:42 AM
Nakataco
02-18-2011 08:14 PM
squidremz
04-11-2008 02:35 AM
fosterfriday
07-24-2006 03:05 AM
deejay
04-13-2006 08:17 PM
Quick Reply: 2007 Klx 250 electrical prob.
