1994 KLX 250 cam tensioner question
Hey there riders,
Wondering if the cam tension is automatic or if it needs to be manually adjusted on this model? There is a washer under the tension adjusting bolt head, I suspect its an addition from a previous owner for some reason. Any thoughts? Two small connecting 8mm bolts on either side with the main cam tension adjusting bolt in the middle, does that sound right?
Thanks
Thanks
SDRRider
07-06-2006 09:00 PM
