1993 KX fork swap
Old 04-19-2016, 06:08 PM
queen of spades's Avatar
Default 1993 KX fork swap
Anyone here swap fork legs with a '93 KX125/250? Do you also have to swap the triple clamp or just simply slide in the new legs and go?
Old 04-19-2016, 06:24 PM
zomby woof's Avatar
Search KLX/KX fork swap, you'll find a good thread on thumpertalk.
I have a set of those forks and may be willing to part with them.
Old 04-19-2016, 06:26 PM
I did search and saw some threads but for the KLX-R owners.. the S models have the ignition switch built into the top clamp so I can't swap the entire tree. Hoping the legs will swap out -- why didn't you use the forks you have available?
Old 04-19-2016, 06:33 PM
zomby woof's Avatar
I am buying a different setup for my bike.
Article here, and the stock triples work. I think i also have the KX triples, too.
HOW TO INSTALL KX-250 FORKS ON THE KLX-300
Old 04-19-2016, 06:37 PM
I read that article earlier. He is swapping internals and not the whole fork legs (in order to keep the same ride height).
I want to swap legs to get a little taller seat height, so that article isn't as helpful for me.
What setup are you going with?
Old 04-19-2016, 06:38 PM
Brewster's Avatar
Be sure to compare the length of the KX and KLX forks from axel to top in order to keep the steering geometry the same.
Ride on
Brewster
Old 04-19-2016, 06:42 PM
Brewster's Avatar
KX forks are modified to be the same length as the stock KLX forks.
Ride on
Brewster
Old 04-19-2016, 06:46 PM
Yeah that's not what I want.
Since I cannot find anyone with a KLX250S who has done this swap, I've picked up a cheap set of 93 forks on Ebay and will see what all is involved. Again, I want increased seat height which the KX forks supposedly offer. I'm also using a set of 112.5mm oem KDX200 pull rods to give a little more height on the rear.
Guess I will make this thread my info/how to.. if it can be done at all.
Old 04-19-2016, 06:53 PM
Brewster's Avatar
Did you also get the KX front wheel and axel or will you be adapting the KLX assembly?
Ride on
Brewster
Old 04-19-2016, 06:55 PM
I have no idea what all is involved yet since there is zero information that I can find specific to the 2006-2007 KLX250S.
Quick Reply: 1993 KX fork swap
