14/45
RE: 14/45
Does any one know of a part number fot the 14 toothfrom rockymoution.com so I can order it from them. Thay dont list it for the klx250 but is it the same part number on a diffrent bike? so I can order everthing at once
Thank you josh
Thank you josh
RE: 14/45
Hey comon6969, what happened to your stock 14t front sprocket?
I am actually gonna put on my new 45T renthal and new chain today using Kawi Wawi's awsome chain removal/install write-up. (THANKS KAWI)
My bike is mechanically stock, all upgrades are either cosmetic or saftey, so I should be able to give you a reasonable review going from a 42T stock sprocket to a 45T. (front is still 14T stock as well)
I will also be adding new trakmaster tires withrim locks as well. Plus a bunch of other goodies.
I'll let ya know later on today how I make-- out if your interested.................
Dave
Dave
RE: 14/45
ORIGINAL: cmon6969
RE: 14/45
While any klx 300 REAR sprocket will work because of the same hub I believe..........BUT the klx 300 front sprocket will not fit the klx250.
****keep in mind I get the info straight from this site*****
Comon6969-check the very first sticky up top on main page...
#1 Common Part numbershttps://www.kawasakiforums.com/m_34306/tm.htm and look at.........
#2 Welcome new members https://www.kawasakiforums.com/m_32128/tm.htm ................it has it all in there........
Any technical info I have is directly from this site by using SEARCH, asking on the forums and reading those few posts...............I am mechanically useless and without such posts from the members here I wouldnot be riding because my bike wouldalways be BROKE!!!![:'(] Thanks Guys................
Dave
Dave
RE: 14/45
The rubber insert is not going to help with thenoise when you are moving. It will only cushion the shifts mainly from neutral to first. The reason for the increase in noise is because you are running a sprocket with a smaller diameter. It doesn't matter if it has rubber or not it's going to make more noise if the chain has to turn in a smaller radius.
I have a 13/45 on mine and it does run high rpm's at 65 or so. If I were going to do mostly streetriding which involved a lot of highway milesI would switch back to the 14/45. For the dirt you cant beat the 13/45 or the same ratio using a large rear sprocket.
RE: 14/45
ORIGINAL: EvildoerZX10R
P.S. I have the XL650 sprocket on mine seems ok so far
RE: 14/45
what size chain shoud I order for the 14/45.for the rear sprocket what other bikes will work becfause rockymoution .com does not list a 45forthe klx300 in the primarry drive brand.
Thank you josh
Thank you josh
