13t update
13t update
OK gents, I have 2150 miles on my 13t. After dirtin' this weekend, chain chirping was driving me crazy all the way home. Inspected the 13t and noticed it was worn quite a bit, It looked like 5000 miles of wear. So I have changed my gear set from 13/45(3.46) to 14/48(3.428). I am planning on 14/49(3.50) soon. The 48t hits the lower chain guide/guard if your less than #3 on the snail adjusters, so I had to add one more link to the chain. This also relieves the added wear on the rubber guide which sits on the swing arm. IMO the 13t is the best first mod, and the least expensive. As the budget allows, and parts wear out, think about the 14t and larger rear sprocket(longer chain) for long term use. If I can get a good pic of the 13t, I will post it tonight.
RE: 13t update
So I should just go ahead and get a larger rear sprocket then the front?? I am just gathering all the money to purchase all the mods at once. Sounds like you recommend a new rear sprocket paired up with the stock front, correct? How many teeth do you recommend on the rear?
RE: 13t update
ORIGINAL: incabiker
RE: 13t update
Thanks for the info, I was just about to go ahead with the sprocket change as my first mod. I guess I'll wait and see if anyone else has had similar problems. If anyone else has more input on this subject, please let everyone know.
RE: 13t update
ORIGINAL: a16tony
Doing all the mods at once, that bill is going to suck
ORIGINAL: incabiker
RE: 13t update
Using my KLR650 as an example. Front sprocket changed about every 5000mi( using a 14t, stock 15). The rear has 38,000mi and still looks good. Steel rear sprockets last a long time, the bigger the better.
FYI, 14/45 requires a 108L chain. 14/48-49 109L. Stock is 106L
RE: 13t update
ORIGINAL: a16tony
RE: 13t update
ORIGINAL: motoguy128
A complete chain will always have a even number of links, with the masterlink being counted as number 0 or 1xx +1. 14/48 might still work with 108, but I'd order a 110 just incase. You can remove 2 links.
ORIGINAL: a16tony
RE: 13t update
I'm sorry, I have that backwards... you can't have an even number of links. You will always have 1 extra "inner" link plus tyhe masterlink to connect the two inner links together. But anytime you change the length, you must add or remove 2 links... 1 inner link and 1 outer link.
For example the stock 106 length has 52 outer links, 53 inner links and 1 masterlink. To go to 108, you add 1 inner and 1 outerlink. I bought a 110 when I installed my new rear sprocket and removed 2 links.
RE: 13t update
ORIGINAL: a16tony
My original stock chain should work ok with the 13-42 gears right. No need to buy a new chain right?
