13 tooth sprocket confussion.
I've been dying for a 13 tooth front sprocket. I've found several but, being an aftermarket mod, nobody seems to want to commit to whether it will work or not. Kaw part numbers don't help unless these is a cross over.
Is there a specific part number and where is the best place to get one?
Thanks.
Thanks.
The washer behind the nut is bent hammer this flat and the nut comes off easy. Just make sure to bend it back a little after you put her back together.
