13 tooth sprocket
13 tooth sprocket
This is a stupid question. I just got my sprocket in the mail. I am guessing that I need to fold down the washer around the nut that holds in the existing sprocket, loosen the bolt, pull out the old sprocket, and do the reverse for installation. Am I right? (I am about to starttearing it apart)
RE: 13 tooth sprocket
Yes take a large screwdriver and tap it back straight. Then take a 1/2 inch rachet with a cheater pipe and then get someone to sit on the bike with it in first gear and the rear brake on. It should come off. Does the new sprocket have a shoulder on it?
I have a picture of the new one, but I cant get it to work using the picture button (it is telling me I need a web address for the link.) anyway, if you mean the rubber thing around the stock sprocket, then no. The new oneis all metal.
[IMG]local://upfiles/4019/FC8BF84E70B54D179890AFA9CE0A1DE1.jpg[/IMG]
ORIGINAL: Gomerpile
good luck.
ORIGINAL: Gomerpile
do you know what size socket that is? I need a larger socket
Ahhhh yes, thank you I was racking my brain trying to remember why I bought that 30 mm. After all I did grease the steering bearings a few months ago. It must be the old age setting in.
