13 tooth front sprocket
Has anyone every ordered a 13 tooth front sprocket from Dennis Kirk? If so what one did you get. There are some that are only for the 09-10 bikes then there is one for the 06-10 bikes. Then another for the 06-10 bikes along with many other bikes and 4-wheelers. The reason I'm asking about Dennis Kirk is because I've already got an order put together and I'd like to get everything from one place. I plan on getting a 351 soon, so I may also order a 15 tooth while I'm at it.
Looking for a 13 tooth spocket for an 07. Going on vaction in 3 weeks and I'd like to try one out on my bike. I will be doing about 80% woods riding.
I see in your signature that you have a 13 tooth with part number. I'm going to research this tonight after work.
This is the 13 tooth my local independent ordered up for me.
453- KLX-250S 06-07, KSF-250A 87-03, KEF-300 95-03. - PBI Sprockets
The 15 tooth is a Sunstar 3B115 520-15T
Yep I did. I got the JT 13 tooth sprocket BIN B42-Q01, Part # 80-963-13. I believe it is made for the Honda XR650 but it fits the '06 KLX250S perfectly.
Moose racing shows a different part for pre'09.
Thank you also, but dennis kirk says it's not available anymore.
LordVngr
09-24-2006 06:03 AM
