128jet report
RE: 128jet report
ORIGINAL: scat
Have you checked the filter again to see if you have the moisture issue as before, and if so there is a drian on the air box, is it obstructed?
ORIGINAL: a16tony
I think you will have the same issue, my mods did not change the high volume of air flow across the little carb. Need to stop road spray from getting the filter wet. I've used the stock, hi-flow and no snorkel.
I thought it was cured when I properly oiled the filter, definitely reduced the problem. I going to turn the hi-flow snorkel 180 degrees, just like a speed boat would do.
ORIGINAL: scat
I myself want to do these mods but i am not sure i want to go thru this icing thing, what to do, I thought for sure you had it licked when you found the water in your air box. [:@]
