is a 128 DJ main jet to rich for full ex, an free mods with stock pilot
as the title states, i have full muzzy, dyno jet kit, needle second slot, crank case, smog removed and airbox lid off, i dont ride in water. #128 jet with 2.5 out on kouba needle
should i go get a 125, waiting on muzzy just trying to avoid doine something more tehn once,,,,taking out that crappy carb.
RE: is a 128 DJ main jet to rich for full ex, an free mods with stock pilot
sorry, didn't see the comma. you should be good to go. Not sure what a 128 dj main is in contrast to a keihin, but I had a keihin 128 in Iowa which should be pretty close in elevation to where you ride. Since you removed the lid, I hope the dj 128 is larger than the keihin 128 because you'll need more fuel than a 128 keihin can deliver without the lid being on there. I tried it with mine with no lid and it ran like crap. I put the lid back on and enlarged the snorkel hole and it was perfect.
I'll be doing this same exact thing next week.
i used the dynojet kit as stated..needle and enlarged the hole in the slide, im not worried about the box beigns the seat covers it, i dont foresee much getting in there then dust and thats a filter maintence issue
ORIGINAL: chuck2302
I used the dynojet kit and the 128 needle etc per the instructions and it worked great. I am in Florida at around sea level. Make sure you put the little washers *on top* of the needle clip.
db
db
is this correct for the needle??? the needle is the dynojet one
on the needle i have one e clip, then a washer and an eclip at the top
http://farm3.static.flickr.com/2205/...55099f.jpg?v=0
i just have one clip, but i dont have the dynojet needle either...
this is how mine and most others are set up
