120/100-18 Report
120/100-18 Report
Just a little heads up. If you install the taller 120/100-18 tire on the rear it will affect your gearing quit a bit. I just installed the Trackmaster and it feels like I put my 14 tooth back on. No big deal right!? Just a reason to order a 49 tooth rear[sm=exactly.gif]
keith....
keith....
RE: 120/100-18 Report
What brand of tire? Are there any issues with the width? It's about 1/2 inch wider than the stock rubber right?
And quite a bit taller I guess by the sounds of it.
i would say around 1 inch taller. around 1/2 to 3/4" wider. no rubbing issues. its kenda trackmaster
i just ordered a oem type steel sprocket. made by primary drive. only $18 from rockymountianmc.com. that way if i dont like, i didnt waste $60 on a renthal or something. if i do like it i will upgrade later. keith
