12 volt output to power accessories
Old 09-09-2011, 04:24 AM
go cytocis's Avatar
@BleednGreen68, I find that if I layer up with thermal underwear and windblocking street gear outer shell (as I would for sledding or snow boarding) that I am warm enough with just the grips. Adrenaline from riding in the snow does the rest; no other heated gear needed!
  #32
Old 09-10-2011, 03:14 AM
BillMoore's Avatar
There is a 12V plug underneath my coolant tank. Not sure what it is intended for, but it was an exact match for the quick disconnect on the cheapo portable compressor that I carry on my bike. I checked my wife's CRF230L, and it has an identical plug in the same location.
  #33
Old 09-10-2011, 03:20 AM
Originally Posted by go cytocis
I tapped into a switched power source
hey gocytosis:
where did you tap?
  #34
Old 09-10-2011, 04:35 AM
go cytocis's Avatar
@IDRIDR: The heavier gauge brown wire that feeds both fuses in the fuse box is connected directly back to the ignition switch. The Oxford heated grips draw max 3.6A so I installed a 5A fuse where I tapped the brown wire and ran that to power the grips. No worries!
  #35
Old 09-10-2011, 11:58 AM
drm's Avatar
drm
drm is offline
Default factory?
Are these factory connections?
  #36
Old 09-10-2011, 05:35 PM
BillMoore's Avatar
Yes, both bikes came from the dealership with these connectors. They have a snap off cap on the end covering the contacts.
  #37
Old 09-10-2011, 05:58 PM
Highbeam's Avatar
Those were probably for the battery tender. Little black plug about 1/2" by1/4" with one conductor exposed? Mine is always plugged in when put away.
  #38
Old 09-10-2011, 06:27 PM
BillMoore's Avatar
Yeah, that sounds like it.
  #39
Old 09-11-2011, 04:06 PM
seth6025's Avatar
I didn't even know that there was one. I will have to take a look when I get home. Frigin work all weekend.
  #40
Old 09-11-2011, 05:24 PM
drm's Avatar
drm
drm is offline
Me too; live to work. I will take a look too. I have a 12v outlet but I may need more than one hookup for power and am thinking about a aux fuse block of some sort.
Quick Reply: 12 volt output to power accessories
