100 mile check up
Old 09-01-2006 | 07:32 PM
ntloser's Avatar
Default 100 mile check up
Hi,
Is there anything I should do at 100 miles that isn't listed in the manual?
When should I do the first oil change? What oil and oil filter do you guys use?
Thanks
Old 09-01-2006 | 07:47 PM
shelby's Avatar
Default RE: 100 mile check up
I changed my oil at about 575 miles. I used Kawasaki 4 stroke 10w40 and filter from the dealer. I went with the easy break in method though.
You might want to check the slack in the chain and make sure the bolts and nuts are still tight.
Old 09-01-2006 | 08:47 PM
Yea keep riding and have fun. Ok seriously I changed oil at 40 miles after the Mototune break in, (not meant to start a break-in debate) and then again at 200 then 400. Check the chain slack and always and I mean every time you ride, make sure the brake light is working, its your best defense from other drivers following you.
Old 09-01-2006 | 09:06 PM
ntloser's Avatar
Cool I am going to do the oil change on Tuesday.. I gotta pick up the manual too.
Old 09-03-2006 | 05:45 AM
Bad Bear's Avatar
I changed mine at 500 miles with Silkolene Semi Syn and it seems to shift a bit smoother
deej
10-11-2014 11:49 PM
kgwld1
12-12-2008 12:37 AM
pie4foou
02-01-2008 12:53 AM
greenkow
KLR250
04-03-2007 05:54 PM
a16tony
11-04-2006 01:44 AM
Quick Reply: 100 mile check up
